Salta al contenuto principale
The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
Yellow spots after digitizer swap
Hey!
After changing the digitizer on my Nexus 5 for the second time, i have yellow spots on the corners. I guess it's the glue. The first time it didn't happen.
What's the best way to get rid of yellow spots? Will i just have to wait a couple of days in the hope the glue is completely dry? Or will i have to keep a white background on maximum brightness for a long period of time, or show some UV light/sunlight directly to the screen for a couple of hours? Or will i have to open the screen again, but what would i need to be looking and doing then exactly?
When you put the phone in the freezer for 15 minutes the spots are almost gone, but they reappear after the display gets warmer. I don't think dryer would have any benefit here, or will it?
If you use white background, the spots are visible like burning-like, when you use pitch black background you see this "black eating" effect on the corners strongly that wasn't as noticeable before the screen swap. The display itself is OEM original, and the first swap was successful, didn't result in any yellow spots.
I read that it was a common thing for iPhone 4s back in the days as the glue wasn't dry enough from the assembly line, but after a couple of days the spots went away.
it looks like this:
https://lh3.googleusercontent.com/-M9xV2...
Thanks!
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Hi misterX
I think that your LCD is broken. Maybe you push it during installation of the digitizer but most likely it is not going to disappear.
Punteggio 0
2 Commenti:
No, i don't think the display is broken. It's most likely glue related. Even the fact that it will fade away when you put it in the freezer. Guess the glue is somewhere in the display and when it gets warmer (softer) it starts to display on the screen.
da
Maybe I am not sure what i know is that iPhone LCD with problem like that I need to replace the LCD because there is no way of sorting this out.
Sorry I couldn't help
da
Aggiungi la tua risposta
misterX misterY sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 459
