Salta al contenuto principale
Repair guides and support for phones manufactured by Lenovo.
Phone won't accept charge/turn on
So 2 days ago I accidentally fell asleep on the couch whist watching a video on youtube and I woke up and my Lenovo A6000 phone was dead (drained battery) which was understandable so I put it on charge before I left for school and when I came home it still wouldn't turn on, the charging icon thing wasn't even on the screen. I checked every thing already. I tried turning it on by holding the power button for about a minute, I tried my charger (the original one that came with the phone) on my Mom's phone and it worked perfectly fine so I what I did was just let it rest for a few hours so before I went to sleep I charged it again, woke up in the morning still nothing. How do I fix it? Does this mean I have to change the batter pack or the charging slot? I also tried blowing on like the metal thing that connects the battery to the phone and did the same thing to the charging slot, even blotted it with some cotton thinking that maybe sand or moisture just went in.
Questa è una buona domanda?
Punteggio 28
12 Commenti
I brought
new Lenovo mobile but asking some setting pls help
da
For new purchase mobile wh need to setting for Lenovo pls help
da
my lenovo a6000 not start proplem
da
i have the same issue.
my sister blugin my phone to mp3 player then my phone becomes dead what can i do.
i always tried your solution but it doesn't work?
da
I thought my phone battery was drain after that I came home and tried charging while charging I was texting and suddenly my Lenovo A6000 switch off automatically and automatically on twice as just a blink with logo and it never turn on and I thought it's dead but when I removed their battery and tried connecting charging cable it automatically on as a blink for few second please help me in fixing it
da
Mostra altri 7 commenti
Aggiungi un commento
17 Risposte
Soluzione Prescelta
FIX YOUR PHONE
Remove the cover and then disconnect the battery and hold on power key then charge the phone without battery for 7 sec and then clean the battery plugs not with water dry cloth and then connect your phone
this is because of a minor power failure in motherboard and keep the phone for charging.
your problem is fixed! insta: alenbinu_
Punteggio 29
51 Commenti:
alenbinuabrahamleo you're awesome! I was upset and sad that my phone is broken but you saved my life :D i have Lenovo S856 and i like so much this phone, thanks a lot!!! Best regards :)
da
thanks for the comment.
da
this really works dude
da
Hi, I am having a peculiar issue with my Lenovo a6000 plus. One day it's battery indicator started showing abnormal results. The phone hearted up and got switched off. I tried to switch on the phone with another battery but failed. Tried to charge the battery but again failed. But when I removed the without disconnecting the charger suddenly the phone woke up and started showing charging indicator on screen. That's not the end of surprise. I pressed the power button for a while and the phone got switched on. But when I took off the charging cable, phone got switched off. What the issue with my phone? Why it's getting switched on without battery when charger is connected? Kindly help me.
da
will this work for lenovo a7000 also?
da
Mostra altri 46 commenti
  • Charge Your Phone For a Few Minutes
  • Pull the Battery or Long-Press the Power Button
  • Perform a Factory Reset From Recovery Mode
  • Restore Your Device’s Firmware
If still issue exits go to Lenovo A6000 Manual for help.
Punteggio 2
Hey..
All the options above are NOT working for me.
Punteggio 2
Hi,
Have you tried a hard reset?
Be aware that a hard reset will erase all your downloaded apps and user data. It will restore your phone to a factory default condition. It will be like when you first bought it.
Here is a link that show how to perform a hard reset for your phone. Scroll down and follow # option 2
http://www.hard-reset.org/factory-defaul...
Punteggio 1
1 Commento:
I have the same problem but it is not resolved even after factory reset. Can you help me? I have Lenovo K8 NOTE
da
I had the same problem this morning. Upon Using a different charger nothing helped. Luckily when I took the battery out and blew on it, the phone booted again after putting it back in.
Punteggio 1
3 Commenti:
I am having this problem with my brand new Lenovo A6010 since yesterday. The red light that indicates charging is lit on while I put on charge all last evening. But never turned green which it should if battery was charging.
Day before I had the same problem but the phone was on after taking the battery out and back in after a while. Since yesterday, that didn't work. Today, I have also tried both the soft and hard reset but still no luck.
I desperately want to fix it, because its a gift and brand new for just a week. Please share a solution for me.
da
I used lenovo K80M model...i got the same problem too...the battery cannot be removed. It attached on the phone. I have tried the tips that was given but not succeed. When charged, there is the signal indicate it was charging but it cannot start even if i press any button
da
My lenovo a 6000 is not charging normally but when it switched off it charged. How this problem is fixed.
da
Hi broooo...First u do one thing....
Step1:first remove battery
Step 2: Then hold on power key for one min
Step 3:after put the battery....check it...
Punteggio 1
6 Commenti:
After then is not on mean ..some motherboard problems....First u check ur charger output.....I think high voltage some time motherboard gone faulty...okay
da
Bro i treind your formula removing the battery wala but my screen will not show anyrhing but it vibrates
da
da
Hi, I am reboot my lenovo a6000 phone last night but didn't reboot then I remove my batter again press the power button it doesn't turn on and it keeps showing lenovo android on the screen but doesn't turn on any one facing this problem please help me
da
android system utility its stuck in recovery mode so u should
first enter the android boot menu clean the cache and format the phone....
da
Mostra 1 altro commento
Try taking out the battery, then put it on a charger without the battery in it. When i did that it made a little buzz sound and i saw that my phone was accepting charge again. Now you might face another problem getting stuck in a boot loop. What worked for me was turning the phone off again, but just with the battery in it and charger connected and held both volume keys but not the power button. And it took me to CwM recovery. I don't know if your phone has it by default, but i have it. I have the a600 golden warrior
Punteggio 1
I am using lenovo K50a40 . One day it so happened that my phone was showing 0% battery and after few minutes it got switched off. Since then it is unable to switch on and boot. I tried my best to remove the cover then plug in the phone without battery but nothing happened. Can anyone suggest me the best solution to such issues. I will be very thankful.
Punteggio 1
1 Commento:
Good morning i have a Lenovo vibe c i was watch an highlight of a match and my phone went off since if i switch it off it just shows Lenovo and it goes off n keeps vibrating please what should i do please.
da
I have Lenovo a5000.it does not start even battery is not empty.then ,if I discharge battery fully and keep the phone and battery in deep fridge,it starts again and and 2/3 days it starts same problem.I changed battery also.but problem is still her.
I searched internet for same problem.but nothing found.
if any one can give me solution ,it will helpful for me.
Punteggio 1
Ok Bro change adapter setting I give you two links follow them it will definitely help. https://www.youtube.com/watch?v=8Aw3Odxf...
Allinguides.com
Punteggio 0
2 Commenti:
i have lenovo 6000+. i have this problem and i did this, but when i discard power cable. phone again restart
da
place a piece of paper with the battery to hold the battery near to the port and conect your phone to the charger
Punteggio 0
1 Commento:
I tried using this on my lenovo a369i it worked but after 3 or so days my phone's not opening anymore T__T it's charging but the phone's not opening.. when i tried to press the power button only the logo showed then it turned black T___T
da
your charging jack isn't working properly & u need to repair it. may be your battery got damaged.
u should have to check it or change
Punteggio 0
The charger may need replaced
Punteggio 0
Haha
Punteggio 0
I am using Lenovo A6000 In a Custom Rom. After flashing the another Rom by formating the existing, my device gets vibrating again and again and doesn't getting into bootloader, recovery or anything, phone keeps black screen. But it is Vibrating, please help me
Punteggio 0
Hello .. I have a Lenovo k5 vibe plus set and it shuts down when I stop using the phone . when I lock the phone and after a minute the phone shuts down without any indication . and then the power button does not work so I had to remove the cover and take out the battery and then I put it back again . this is happening to my phone .. Can anyone suggest me what to do.
Punteggio 0
1 Commento:
I have a Lenovo k8 note(undetachable battery), I have a similar issue that my phone went off while charging and after that it's not switching on nor charging. What should I do?
da
My lenovo A316i mobile is not power on how to fixed please solve my problem please
Punteggio 0
Aggiungi la tua risposta
JGL sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 45
Tutti i Tempi: 123,695
