not charging nor detecting charger.
Doesn't detect charger connection. Battery is full discharged. Random flicker of the screen as if accepting charge. Then nothing including battery is being xharged
Questa è una buona domanda?
Are you using the original charger? These devices don't like charging from flat otherwise. Another possibility is that the battery has dropped below the 0% mark (3.7v), This is fairly common if it has been left sitting in a flat state
I've heard around that to fix this is to open up the tablet then unplug and plug the battery connector to fix this problem.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 104
Did you try a different charger?
da Joel
