Salta al contenuto principale
Released September 2015, the JBL Xtreme is a portable, Bluetooth speaker that is also splash proof.
Is it possible to check the speaker internally?
I would love to see inside it. Many people have purchased this model. thank you
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Risposta Più Utile
@atomic take a look at this video
Punteggio 2
See inside as in open it up? I had to open mine up because I dropped it and I wouldn't recommended it. The item is non-repairable as stated from manufacturer, and if you open it up like I did, you won't be able to close the casing as tightly as in original condition (I presume the waterproof tolerance has been affected because of this). There is some glue underneath the casing so I suspect this helped hold it in place.
Punteggio 1
Aggiungi la tua risposta
arash sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,526
