Where are the power pads to short it on?
I’m looking for the pads to touch to short it on to check to see if my keyboard is broken.
Questa è una buona domanda?
David Molinari you can do this by either shortening pin 5 of the keyboard connector briefly to ground. You can also use the debug pads as pointed out.
Thank you very Much oldturkey03!
Hey! When I short the two pads it turns on but the fan goes on at full speed and doesn't stop. Where is keyboard connector 5 by the way? Thanks in advanced!
Hi, thank you so much!!!! I've been searching these power-on pads for so long...
I "only" have to replace the keyboard now.
Must i disconnect the keyboard in order to power up with power pads ?
francoisvdc no you do not.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 62
Tutti i Tempi: 22,751
