Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
1525 Domande Visualizza tutte
My Device Is "Searching" for carrier (No Service)
I have an iPhone 6 plus, running on iTunes 9.2.1 (newest update). As of yesterday around 4pm my phone started to search for a network and will not connect. I went to the AT&T store and they put a new sim card in my phone and it still will not work. Can some one please help me?
I have toggled airplane mode, took out sim card and cleaned it, reset network settings and finally I erased all settings and content (after a back up) and restored to factory settings. STILL does not have service.
Any Advice?
Thanks friends.
Travis Fox
Questa è una buona domanda?
Punteggio 1
1 Commento:
Did you fix it? I'm having the same problem.
da
Aggiungi un commento
3 Risposte
Did you replace the screen?
Punteggio 0
1 Commento:
no I have not replaced anything. it is 100% factory
da
Are the time and date correct
Go to settings and make sure they are correct
I had this on an iPhone and couldn't get wifi in an iPod when for some reason the date had went back to 1970
Punteggio 0
Has this problem been solved yet I'm having the same exact problem and getting the run around a from T-Mobile phone was working perfect then stopped about 3 weeks ago
Punteggio 0
Aggiungi la tua risposta
travis fox sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 427
