Salta al contenuto principale
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218 Domande Visualizza tutte
Charging area got slight water damage, no charging
iPad4 - I had recently let my iPad get slightly wet for a few hours on the bottom in about a centimeter or half an in. of water. Everything works fine, but it won't charge any more. It did charge for a bit after being wet, but eventually just stopped charging. I think something is corroded on the charging connection hardware. Would I be able to fix it with replacing the Lightning connector?
iPad 4 Lightning Connector
Thanks for your help.
Immagine iPad 4 Lightning Connector
Prodotto
$19.99
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Most likely. iPads are kind of a lot of work to get into though.. At any rate it's most likely just a new lightning dock
Punteggio 2
1 Commento:
Thank you for your time.
da
Aggiungi la tua risposta
Daniel Furey sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 63
