Salta al contenuto principale
The Canon PowerShot G16 is a 12.1 Megapixel point and shoot camera made by Canon and released in 2013.
5 Domande Visualizza tutte
Why aren't my pictures transferring to my computer?
I am trying to transfer pictures over to my computer, but my camera and SD card are not showing up on my computer.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
There are a few reasons pictures may not transfer to your computer. If you are trying to transfer the photos by directly plugging in the SD card, two possible reasons are
  • The SD card is not inserted properly in the SD card slot on your computer
  • The SD card contacts are dirty
If you are connecting the camera by a USB cable, two possible reasons the pictures are not transferring are
  • The USB cable is not properly connected
  • The connections are blocked by debris
Some solutions for the SD card problem are
  • Ensure the SD card is inserted properly. Depending on your reader a portion may still be exposed
  • Clean the SD card contacts by gentle cleaning them with a small amount of rubbing alcohol
  • If you feel that the problem is with the camera not reading the SD card, please refer to the troubleshooting guide
Some solutions for the USB cable problem are
  • Ensure the USB cable is plugged in the appropriate port on the camera and on your computer
  • Unplug the USB cable from the computer, and replug it in back into the computer
  • Check to make sure that there is no debris in the ports on the camera or computer and clean them out if necessary
Punteggio 0
2 Commenti:
camera works fine - card transfers over to the photoshop wherever that is - but does not show for 2019. all other photo are there -
da
I think it is with the camershop I do not know who develops them on my computer but they come outperfect. They are just not listed for 2019 on my listing on m y computer...…..so therefore, I cannot add to an email???????
da
Aggiungi la tua risposta
Jonathan Harger sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 5,625
