Salta al contenuto principale
Modello inizio 2011, A1278 / processore i5 2,3 GHz o i7 2,7 GHz
782 Domande Visualizza tutte
Upgrading from HDD to SDD, but get prohibitory symbol when booting up?
I am upgrading my early 2011 MBP 13" from the original HDD that came with it to a Crucial M500 240gb SSD. When I use a bootable USB that has OS X El Capitan on it, the installation is very slow on the SSD. It actually take over 2 days, but the progress bar didn't budge. I suspect the SATA cable is damage and needs replacement, which seems to be the case according to various message boards including this one.
However, I have another MBP and an external enclosure which I put my Crucial SSD into and install El Capitan to get it fully running, and then I physically install it into my early 2011 MBP 13", but I get the prohibitory symbol (Circle with a slash inside of it).
I'm curious if replacing the SATA cable will be sufficient enough to fix the problem, or do an underlying issue that I need to also fix (regarding the prohibitory symbol).
I'd be happy to answer more questions if any further clarifying is required.
Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You'll need to start there. Replace the SATA cable and reformat the drive and install the OS again.
Punteggio 2
Aggiungi la tua risposta
Tom sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 396
