Salta al contenuto principale
Repair guides and support information for RCA-brand tablets.
Sound only works using headphones
Sound won't work only on headphones
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
Risposta Più Utile
@hkerry could be a bad speaker, bad connection or a stuck headphone jack. It will help if you can tell us what model your tablet is. At first I would try to clean the headphone jack. Insert and extract the headphones a couple of time in rapid succession, use a few puffs of compressed air to blow in it.
Punteggio 3
2 Commenti:
sound ONLY works with headphone plugged into unit - RCA PRO12 2-in-1 for android. Unit is less than 2 months old.
da
@harriet1986 besides trying what I posted in the original answer, I would contact whomever you purchased this from. Since it is only a couple of month old you should address any warranty issues first.
da
Aggiungi la tua risposta
beth hayes sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 846
