Salta al contenuto principale
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
ipad mini error 4013
Hi guis i have a promlem. my ipad mini have error 4013. somebody can help me???
pleade
Questa è una buona domanda?
Punteggio 1
1 Commento
Try a different USB cable. The iPhone error 4013 can be caused by a hardware problem. It's possible that the iOS device is disconnecting from iTunes, or iTunes can't communicate correctly with the device, because the cable connecting the device to the computer is faulty.
Regards,
Will
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Error 4013 is usually a usb problem.
Use the USB cable that came with your device, or a different Apple USB cable.
Plug your cable into a different USB port directly on your computer. Don't plug it into your keyboard.
Try a different computer.
Solve other issues with the USB connection, then with your security software.
Punteggio 2
7 Commenti:
i have try 3 cable and 2 cpmputers
da
Ok. Are they aftermarket ones?
da
One original and two aftermarket. But i have resto Red some iphone with this Cable
da
Don't trust aftermarket cables. Also try the other things I said
da
I tried everything but nothing. It could be the USB connector?
da
Mostra altri 2 commenti
4013 is NAND error. try replacing front camera
Punteggio 1
3 Commenti:
how is the camera related to the NAND?
da
A faulty front camera can stop the device restoring.
da
forgot how pesky apple is with EVERYTHING. upvote. my apology
da
Aggiungi la tua risposta
Pasquale sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 5,685
