Salta al contenuto principale
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
142 Domande Visualizza tutte
Domanda Chiusa
Sound does not work
I have the same problem as this one..The sound works intermittently.. I went to preferences/sound and it would not let me highlight anything in the output or input section and it displays "no output/input device found". The sound was working fine.. then it does not. I do not change anything, I am not that clever. Could it be the cord between the computer and the monitor?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If you have the same issue as that one, then you either need a new logic board or can use USB-equipped speakers to bypass the issues. The USB speakers would probably be the cheaper alternative. You can start looking for USB speakers that are compatible with a mac (double check!) HERE.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 984
