Salta al contenuto principale
Black and silver single cup coffee maker with water reservoir on the left hand side. K40/K45.
98 Domande Visualizza tutte
Why does it not pump water?
Keurig has always had in tank filter change regularly. Made two cups this morning then I proceeded to make the third when there was the pumping noise then a click then drip then nothing. Is this fixable? What would it cost to have it fixed? Just estimated is good. Thank you
M.cooper
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Melissa Cooper most of this is possibly caused by clogged lines or valves. Try to clean the filter and puncture needles. Use this guide to work on it. Let us know what you find.
Punteggio 2
Aggiungi la tua risposta
Melissa Cooper sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,078
