Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
iPhone 4S Logic Board Replacement, Where to buy - kksilvery
Recently my iPhone is not working , Apple Logo loop when turn on then t turns off, according to my engineer , it requires logic board replacement.
I tried to restore it by putting it on recovery (NOT DFU) , it showing up iTunes error 29.
Where can i get clean imei board under 40$. Im from india if any of you have a spare or a board which do not need then sell it to me via courier or ebay etc etc.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Hi,
I had this same issue with my iphone 5c. It turns out that it is to do with the antenna that is near your battery. I suggest taking it out and putting it back in again. Please also clean it! So many people get it wrong but your oils from your finger can mess up the system, clean it with windex (not too much though). Also going back to your question the best place to buy is either gumtree or ebay. If you want a trusty motherboard for a little bit more money I would get if from here! At least you know it wont break. Please help me as well. Questions and comments on my page: Iphone 4 does not turn on after getting to step 9 on replacing screen, it might have something to do with the cable however I don't know. Thanks,
Max
Punteggio 0
2 Commenti:
hope it helps!
da
Kksilvery thank you for good suggestion .... Unfortunately it dint work out for me .
Kksilvery.
da
Aggiungi la tua risposta
krishna kumar silvery sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 86
