Broken Home Button - Mainboard Failure -HELP
Hello Guys!
The Home Button of my Ipod touch is Broken.
Its very hard to describe, what happened. So I painted some Pictures:
I HOPE You understand what I want to tell you. The Home button itself, is on a little plate. This plate gives a Contact, to the Blue metal Plate on the Mainboard of the iPod. On this blue Colored Place (Of course, its silver in real) is a little metal Spring. This spring is Broken down. I can solder it on the Mainboard, believe me - I can ;) But the Problem is, the Home Button still doesnt work. So I tried to Short circuit the Contact between the Metal Plate and the Bigger Resistor. If you believe me or not, but when I short circuit it, The Ipod thinks I pressed the Home button, The running app will be Closed.
So what now? It seems, there is no Contact between the Metal plate and the resistor anymore. Whan Can I do now?
I dont have a Camera with a high Resolution, that means I can't shot a high Res picture.
Greetings, Kentsfield
Edit: OH HEY! I shot a few pictures, which are - Well, lets say, acceptable.
Original Picture
Edited Picture. YOu can see the Blue place, and the Trace to the Resistor which I meant.
When I short circuit the blue place and the Resitor, the iPod thinks I pressed the Home button.
Questa è una buona domanda?
3 Commenti
Unfortunately, yes. I am still waiting for a solution for this problem, but I believe that there will never be an answer.
greetZ kentsfield
da Kentsfield
Does anyone know where the pad is connected to? on mine the entire pad is lifted and gone, and i can't see any traces coming from it.
da cj anderson
cj anderson
- For future reference you posted a comment in the place where only Answers belong. Please use the Add Comment link, or start your own Question.
da originalmachead
