Salta al contenuto principale
A portable, all-in-one, desktop with touchscreen manufactured in 2013 by Dell. Model Number W01A can be found by checking the device's right support foot.
13 Domande Visualizza tutte
Domanda Chiusa
XPS 1810 battery drains 7% every 24 hours.
I've got Dell XPS 1810 with i7 and 8Gb RAM onboard. OS: Win 8 64bit.
One day I noticed that the battery lost about 9% of its charge in 24 hours when the computer was properly shut down. No sleep mode, no hibernation. Just correct shutdown.
On 1 Dec 2015, Dell-authorized repair shop replaced the battery. It is now a brand new Dell battery, part D10H3. But the discharge issue is still there, now the discharge rate is 6-7% in 24 hours when the computer is properly shut down (no sleep mode, no hibernation). This charge loss is not related to the charge needed to boot up the computer, since when I leave it for 3 days (1 day = 24 hrs.) and then turn it on, the charge loss is 3 x 6-7% = ~20%
I am sure it is not normal. After 15 days of not being in use the battery would drain to zero. And it cannot be easily removed from the computer, it is an integrated battery.
What is this problem all about? Battery replacement has not solved it.
Questa è una buona domanda?
Punteggio 0
1 Commento
Hello and thank you.
This machine runs under Windows 8.
I tried hard shutdown before (holding down the power button), but it never helped. The same draining. In fact, no matter what I did, there is battery draining as I described. Sorry, don't know about hibernation or sleep mode battery use, I never used those modes.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
There may be issue with the power off program itself the command may not be complete. Try powering the machine off by holding down the power button until it shuts off and ignoring the menu . This method of powering off bypasses the android power commands . Have your tablet completely charged and see if there's a power loss after powering done this way. If there is no power drain then a new rom may need to be installed or maybe if your lucky just restoring the system to factory default may be all you need. You could also just power down this way . How much power is used over the same time frame when the machine is in hibernation or sleep mode?
Hope this helps
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 588
