Salta al contenuto principale
1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
How can I troubleshoot keys not working
I changed the display assembly following the great guide.
Unfortunately I must have messed up something. The shift keys and a few function keys are not working anymore.
I connected a bluetooth keyboard and it works all fine with that one. I assume that it is some hardware issue.
Is there something I can test before changing the keyboard
Maybe some cables that are not connected
Any idea is very welcome
Questa è una buona domanda?
Punteggio 1
3 Commenti:
Can you give us your systems serial number so we can correctly identify which model you have.
da
Dan. The model number is A1370. The Serial number is C02G59XCDJYD.
da
Aggiungi un commento
2 Risposte
try disconnect keyboard strip and try reconnect it back ...if it is a carbon strip clean it with soft dry stuff
Punteggio 0
1 Commento:
I"ll give that one a go once I'm back home. Thanks for the suggestion.
da
My preferred way is to load into OSX Apple>System Preferences> Keyboard, check the box "Show Keyboard & Character viewers in menu bar" Click on the new icon and choose Show Keyboard viewer. It'll give you a digital display of the keyboard that will react to each key that you press.
Punteggio 0
1 Commento:
I did that one and the keys do not react on the keyboard viewer. They react on Bluetooth keyboard but not on the keyboard
da
Aggiungi la tua risposta
Edward Omagbemi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 960
