Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Domande Visualizza tutte
different types of front panel connectors...? (cable #2)
Hello.
I ordered a repair set at Amazon.com for my iPhone 3G.
No mistakes possible one would assume...
Beware ! Connector #2 comes in various types.
Now I am stuck with a wrong front panel. What to do about that?
The old cable says: 821-0766-A (2008)
The new one says: 821-0621-A (2009)
How can one know the differences?
The screens are sold as if it is quite easy to replace a screen.
Not at all!
I have not seen any warnings that the screens/connectors come in different shapes. It shows afterwards, when it is too late.
What can be done about this?
Questa è una buona domanda?
Punteggio 1
1 Commento
Everything is easy when you know.
I did nog even know of the existence of a 3G...
Checking out the websites learned me that you cannot relay on the pictures alone.
The description is also important, but I did not know to pay attention to 3G or 3Gs, for me it looked all the same.
It's not.
You end up by ordering a new part with the correct specs and hope for the best.
Indeed it is eaysier to buy the whole front panel in one piece for sure !
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Same happened to me, I ended up buying the screen plus frame on Amazon just so I didn't have to go through the whole process again. It was MUCH easier, just a few minutes but now my ear piece doesn't work but it might just be the cable isn't connected well so I have to take it apart again.
Punteggio 1
I have had the same problem. I was disappointed when I got the whole thing apart, then back together only to find the cable mismatch at the very end. I'm surprised this has happened as I know that I ordered the correct kit according to the specs on the site!
Punteggio 0
Aggiungi la tua risposta
Frank sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 4,855
