Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
iPhone 5 Pentalobe Screws Spinning
I have refurbished an iPhone 5 into a "6 mini" housing. Done a few of these, no problems. Had to change the battery in one as it could of done with a new one, one of the screws wouldn't come out and now it spins (so not stripped) but turns to a certain point then clicks
any suggestions? don't really know what else i can do.
no access to the screw other then a screwdriver.
i've used a magnet to make the screwdriver stronger but it didn't work
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Try prying up on the screen just slightly as you try turn it out. Sometimes that can push the screw against the edge and get it to come out.
Punteggio 1
Risposta Più Utile
Well. The issue is that the threads of the screw are stripped. Inside the device. So, you could try super gluing your driver to the screw end, and seeing if you can pull it out, probably quickly
Punteggio 1
1 Commento:
That would just make it worse, thanks though.
da
Aggiungi la tua risposta
James Carter sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 8
Tutti i Tempi: 469
