Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Replaced my screen, Touch ID Causes issues
I have replaced my iPhone 6 screen, and ever since I have changed it I have had problems when activating my Touch ID.
When activated, the screen is unresponsive and sticks. I have to restore the phone and then not activate the touch ID for it to work.
Has anyone had this problem?
Questa è una buona domanda?
Punteggio 5
5 Commenti
Did you replace the touch ID?
da
No, just the screen has been changed.
da
Take the phone apart and make sure the cable behind the back light metal shield is securely connected to the touch ID button. Also make sure it is well connected to the motherboard.
da
What Jake said. Sounds like, guessing, the cable to the home button and the back plate are not secured
da
I am taking back to the shop tomorrow, what is happening that the phone is sticking and you need to just turn press the off button and unlock the phone and it works for a while and then sticks again. Could this be the cable issue?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Check the connection for the flex cable of the home button. Or you might need to replace the cable. Take a look at this
Punteggio 5
1 Commento:
da
Aggiungi la tua risposta
John Phillips sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 134
