Salta al contenuto principale
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 Domande Visualizza tutte
How do I stick volume buttons to the bracket
I tore the power/volume cable while replacing the screen. I purchased the new cable and finished disassembly. While trying to reassemble, I peeled the protective covering off of the cable beneath the volume and lock components. When I press them to the bracket, the buttons and switch (the last step/first step in reassembly) will not stick. They pop off when trying to stick the next one on. Is there another adhesive I can apply to get them to stick that will not damage the cable?
Questa è una buona domanda?
Punteggio 0
1 Commento
When using super glue, , I use a needle to stick down the tube of superglue and that way you only transfer a tiny amount of glue from the end of needle onto your cables and it keeps from getting too much glue from spreading to other parts of the cable.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Yes, that a common problem. You can use quality double sided tape, you could use a very small drop of supper glue if it's the only alternative. But only a small amount that only covers the back, without it getting on the front or sides of the cable. Do one at a time and let dry before installing.
Punteggio 2
1 Commento:
I would recommend using super glue as a last resort. Its a pain to deal with if you ever have to work on it again.
A little double sided tape works fine as long as you don't use too much.
da
Aggiungi la tua risposta
Matthew Kovnot sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 173
