Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
issues after replacing Lightning Connector and Headphone Jack
1.
I accidentally bought 'iPhone 5s Lightning Connector and Headphone Jack(BLACK)' when my iphone is white one.
Then replace the original part(which is white) to black one i bought.
So is it okay to use black one in white iphone?
2.
Most of problems i had are solved. after i replace it to new one
But my left side of earphones is still not working. Does it have something to do with 'iPhone 5s Headphone Jack Interconnect Cable'? or if replacing the part didn't work, then it is the problem from the board?
3.
A new problem which i didn't have at all so far got happened. the touch reaction lags and doesn''t work from time to time
Immagine iPhone 5s Lightning Connector and Headphone Jack
Prodotto
$24.99
Immagine iPhone 5s Headphone Jack Interconnect Cable
Prodotto
$5.99
Questa è una buona domanda?
Punteggio -1
1 Commento
I have the issue with headphone jack only playing one side too... have checked setting etc and replaced the part twice. seems unlikely both parts are defective..... maybe 3rd times the charm ? :/
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
The color doesn't matter as fare as function, it's the same part. Make sure the cable is connected properly to the logic board. Most likly the part was damaged or defective. Buy a new part and reinstall. The digitizer (touch screen)cable was damaged or not connect properly to the logic board.
When replacing the charge port remove the screen from the phone.
Punteggio 1
Aggiungi la tua risposta
Artois sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 88
