Salta al contenuto principale
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
20 Domande Visualizza tutte
MacBook don't turn on
MacBook display has no picture after turn it on.
I don't hear any fan or hard disk activity sounds.
the sleep light doesn't turn on.
The computer doesn't seem to have any power when you try to turn it on.
Battery is full; and I tried to switch and/or remove both of ram sticks; no effect.
I tried the SMC reset too.
About the power : the light on the original power cord doesn't turn on green or yellow when plugged on magsafe; but if I use the cord from my new PBpro, it turns on green.
That's it.
Any help ?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
That's not good. worst case scenario, your Logic Board may be bad, or maybe your DC in board may be faulty. You should replace the DC In board first and if that does not remedy the situation then you may have a short on the board. Here is the Part I would replace first.
Punteggio 3
1 Commento:
Thanks for help.
The battery is full, the MacBookPro cord plugged on the MacBook looks working.
I have another MacBook (1 year older) that presents exactly the same syntoms.
400$ for a new logic board. Hum...
Punteggio 0
So, with patience, I finally found a afordable logicboard and replace it.
Now, let's wait for the MBP logicboard prices...
Punteggio 0
Aggiungi la tua risposta
anne guillaume sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,723
