Salta al contenuto principale
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Domande Visualizza tutte
What Logic Board can I use? iMac 27" (late 2009)
I have an iMac 27' Late 2009
i7 2.8ghz EMC 2374 Model A1312
The video connector broke and is not repairable, what models of logic boards can I replace this one with?
Thank You in advanced.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
nmartinez01985, your board should be Apple part number 661-5428. Additional boards that should fit your iMac are part number
661-5319
661-5317
661-5429
Sometimes repair services that offer microsoldering can assist you soldering a new connector in place. Might be less expensive and are an option to consider.
Punteggio 3
1 Commento:
as my USB ports are failed and just left 1 port available, can I replace just the USB port module? ... or I have to replace the logic board at all?
da
Aggiungi la tua risposta
nmartinez01985 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,148
