Salta al contenuto principale
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Domande Visualizza tutte
Domanda Chiusa
Looks like I need to replace motherboard, yes?
I have a Samsung Galaxy S3 that won't power on. It was my daughter's and got submerged in water. I'm new to this and thought this would be a good exercise, so took out the motherboard in search of the problem, and I think I found it.
Check out the attached images of the motherboard, and especially the first one where I've marked what I think the problem is. Looks like some of the components on the motherboard are fried:
I didn't see any other obvious areas of damage, but I'm guessing that the whole thing will need to be replaced anyway.
So I think my next move is to order the Samsung S3 Verizon motherboard and install it by reversing the disasembly steps that I took to remove the damaged motherboard. Simple as that, or is there more to it?
Also, dumb question: what about the Android OS? Is it stored somewhere on the damaged motherboard that is going away, or elsewhere on the device? If somewhere else, I would think that there is no problem with swapping out the motherboard. But if it is on the motherboard, I have other questions (such as will it be present on the replacement motherboard, and if so, what version, and so on).
Questa è una buona domanda?
Punteggio 0
2 Commenti
The new board would come with a its own android os loaded on it, all the information for the phone is on the board of that phone.
da
Thank you for the info!
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I would try soaking it in some isopropyl alcohol to remove that corrosion. Let it soak for a few hours up to a day and than brush the board lightly with a toothbrush. I would than let the board dry for a few hours (maybe up to a day) to let the excess alcohol evaporate. I would try the board again after that. If it is still dead at that point I would try a new board. I hope this helps!
Punteggio 0
5 Commenti:
Ok, thanks, I'll give that a try!
da
The alcohol got rid of that corrosion and the board is shiny-clean. But unfortunately, it still won't boot so I guess I'll try a new board.
da
Sorry to hear it didnt work! I figured it might be worth a shot!
da
It definitely was and it was a good learning experience. I did actually think the chips looked burned; I did not recognize corrosion. Now I know ;)
da
Replaced the motherboard and the phone works like a charm! Great experience, looking forward to my next repair job! Thanks for all the advice.
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 136
