Salta al contenuto principale
Model No. A1367 / 8, 16, 32, or 64 GB capacity
Why is the screen not working?
I just replaced the screen and follow all the instructions. I got a white screen and waited for the battery to run out to reset it. It did. However, the screen does not react when touched. What could be the problem?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Hello,
It could be problem with flex cable, or connector on motherboard. If you've got the old display you could check it. When you gonna put old one with working touch screen and it will work it's something wrong with flexcable on the new display.
-You could check too if flex cable is fully connected.
-You could try to recover ipod with itunes
Punteggio 0
Hi. I just replaced the front panel of the iPod. Did everything as the instructions. Once the white screen was reset, and came back to normal, the screen does not read the touch or take commands by hand. Nothing happened when it is touch by hand.
Punteggio 0
Aggiungi la tua risposta
angelito2k sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 51
