Salta al contenuto principale
Improved second generation Google-branded tablet with a 7" screen.
Nexus 7 Device Charging Help
Device stopped charging. Replaced charging port and still wont charge. Lock screen does not indicate charging. Tried multiple chargers. Replaced battery and conditions remain the same.
Any advice?
Thanks
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Check you cable try a different usb charger some times the block from asus goes bad and would need replacing
Punteggio 0
1 Commento:
I have tried multiple chargers. Ones that work in other devices and it has no effect.
Thanks
da
the asus brick not the cable
Punteggio 0
3 Commenti:
I no longer have an asus charger brick or cable. I have two other Nexus 7s and they charge with these other chargers. Can I even buy an Asus charger at this point? Should I try that?
da
yes ebay carries them cheap
da
asus sells the bricks with them because of certain amperage needed to charge the tablet not every tablet take the same amperage
da
Aggiungi la tua risposta
pmcint01 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 137
