Salta al contenuto principale
GoPro’s seventh generation camera released in late 2012. Capable of recording 1080p30 video, waterproof to 197', and built-in Wi-Fi.
18 Domande Visualizza tutte
Gopro hero 3 water damaged in salt water? help?
It may be too late but last afternoon the case cracked and some water got in, I noticed some salt forming from the water evaporating and also noticed it was getting pretty hot. I took out the battery and SD card but the SD card is broken. Now it will not turn on or charge. Again it might be too late but any ideas?
Questa è una buona domanda?
Punteggio 2
3 Commenti:
I had the same issue , please help !
da
My camera keeps saying no sd card and bippin every 3 seconds, so it doesn't record or connect to my phone.
I try to reset and did not work.
Any ideas anyone?
da
Try swapping out SC Cards, different brands as well as Size of SD Card, Let say from a 64 to 32 etc. It has work for me, Believe or not they do come bad brand new
da
Aggiungi un commento
1 Risposta
I’m not sure who to thank for the information on water damage for my GO PRO 3, cleaning all the internal parts with Isopropyl Alcohol worked, I was about to replace the mother board, and thank you for the tear down information of GoPro Hero 3 as well. THANK YOU ONCE AGAIN
Punteggio 0
Aggiungi la tua risposta
jack land sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 12
Tutti i Tempi: 847
