Salta al contenuto principale
Repair guides and support for phones manufactured by Lenovo.
screen shows everything double. What can I do?
i left my phone for a few minutes on the sofa and then when i come back the screen shows everything doubled.
Questa è una buona domanda?
Punteggio 3
8 Commenti
I have the same problem for a LG Stylo 3 that was stepped on.
da
did u fix it i got the same problem and same phone
da
da
no my phone fell on the groud
da
Does this drain my battery?
da
Mostra altri 3 commenti
Aggiungi un commento
5 Risposte
Risposta Più Utile
Steps
1. power off button on the phone, press it
2. check the pop up on the screen (power off, restart, airplane mode, silent mode, VR mode)
3. Tap on the VR mode.
Bingo! problem solved.
Punteggio 5
4 Commenti:
very good answer and simple but very useful
da
This answer saved me.. thanks a lot
da
I dont have vr mode ,what to do,?
da
I don't have vr mode ,what to do,?
da
When you press switch off button... one extra message is displayed i.e. "VR Mode is ON".... just select that option... you will get back the original screen
Punteggio 2
1 Commento:
Where is vr mode located
da
I freaked out when it happened but I turned it off. Then took the battery out and light pressed on the back where the battery sits. Put the battery back then turned it on then, it was fixed
Punteggio 0
You can't fix it with the apps or in the settings. You gotta repair it or simply just buy a new one🥲
Punteggio 0
My phone shows ng double screen
Punteggio 0
Aggiungi la tua risposta
Dragneel Potter sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 68
Tutti i Tempi: 24,349
