Salta al contenuto principale
The third generation of the Apple iPad, released on March 16, 2012. Full 4G and Wi-Fi model repair guides. Repairs require heat and careful prying. Model numbers: A1416, A1430, and A1403.
Touch not working after replacing screen
I replaced the digitizer only an iPad 3rd generation. I haven't sealed it. It does come on and Siri comes on but the touch isn't working. Help!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
If possible, remove the new digitizer, and test the old digitizer to make sure it's not an issue with the iPad's logic board.
If the old one works, you'll know you need to replace the new digitizer as it would likely be defective.
Punteggio 0
2 Commenti:
I can't put the old one back on because it shattered.
da
I should say I shattered it when I took it off. it only had a crack prior to my replacing it :(
da
Aggiungi la tua risposta
Donna sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 105
