Salta al contenuto principale
A collection of guides and support to help with washer repair.
3478 Domande Visualizza tutte
Machine not working , Error dE
Although the lid is closed and the magnet attached to the lid is intact, the door open error message (dE) is displayed and the machine (LG fuzzy logic model no. T6515TDPT01) stops working after taking two /three turns in wash mode. I seek help from you guys to fix the problem. Thanks
Questa è una buona domanda?
Punteggio 3
1 Commento
Check to make sure that the connector coming from the switch is properly seated on the circuit board.
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Might be the magnet, usually the magnet pushes this switch the shows the door is closed. Hard to explain. Do you happen to have pictures?
Punteggio 1
1 Commento:
I shall fix a stronger magnet and shall see if it works.
da
Power off the machine and unplug it if you receive the error mid-cycle or at the end of the cycle. After five minutes, restart the machine and try to open the door again.
Wait about a minute for the door to unlock if you paused the machine during a cycle. In this situation, the locked door and appearance of the DE error is merely a safety precaution.
Punteggio 1
3 Commenti:
Simple and great solution!
da
I could not get you dear gillrois. plz explain elaborately.
da
Click on the link for troubleshooting LG washer with error code DE. Hope this help Immi.
http://www.ehow.com/how_7850983_troubles...
da
Aggiungi la tua risposta
Immi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 243
