Salta al contenuto principale
The Galaxy Tab Pro 8.4, produced by Samsung, is an Android based tablet which was released on January 2014.
21 Domande Visualizza tutte
charging port does not work
The pin inside the charging port seem to be broken.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione Prescelta
i think you just answer your own question.
Punteggio 1
4 Commenti:
Well, not really. I was hoping for some advice on how to get access to the plug. I didn't find any repair videos on YouTube and no repair manuals
da
Ok, that's a better question. If your problem is the port as you say, you have to swap charging flex cable which is pretty simple compared to Samsung normal approach of soldering port to the motherboard.
Here is a link how to open the tablet
https://www.youtube.com/watch?v=lEVFYQks... (0:25 - 2:20 time)
And here is link to buy DOCK CHARGING FLEX CABLE http://www.parts4repair.com/dock-chargin...
When removing old port from the device be carefull not to damage pinheads in the process. Hope this was more helpfull and gives you enough information to proceed with the repair. Good luck.
da
Thanks a lot. I am afraid my first question went into cyberspace in an amputated version.
da
does the port pull out or do you have to remove the plastic on top of it
da
Is there instructions on how to remove the charging port or flex cable?
Punteggio 1
2 Commenti:
yes is understad
da
was good and wounderfull
da
Aggiungi la tua risposta
terje sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 937
