How do I fix the broken charge port?
Will not charge. The inside of the charger is broken.
Questa è una buona domanda?
Sally Daniel, the charging port is connected to a flex cable. all you have to do is replace that. No soldering involved. Flex cable is available at places like this and many others
I don't think the charge port is USB, it uses a mini cord that should slip over the contact.
i think you need to resolder that USB port
go to ifixit youtube channel and check out resolder of USB port on SGS3, on SGT4 it should be the same
i don't think SGT4 has USB port on doughterboard (so you just replace that little piece )
resoldering that without equipment is nearly impossible
you can buy tools and DIY but it's gonna cost you a bit
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 803
1 Commento
I had the same problem with device purchased May 2015. I just received replacement unit 2 days ago and again have same problem!
da troyerdd
