Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
Domanda Chiusa
Battery does not charge after change
Hi,
i replaced the battery of my iphone 4s. no problem during the replacement process.
After plugging it in again its only showing the battery with 3 small stripes. There is no charging process or other icons like the lightning.
Can someone help me please?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
David, of course you want to double check your work first. After that replace the new battery and see if the old will charge. It is possible that you have a bad battery. The standard way to check will be trying to charge with a different charger (use a wall charger not your computer to ensure a higher amperage) and make sure that you have a known-good cable. Check the dock connector for any broken bend or corroded pins. Clean it with some isopropyl alcohol and a few puffs of compressed air. If all that should fail, you will have to check the charging circuitry on the board. There is always a possibility of pry damage to some small component.
Punteggio 1
1 Commento:
the bad thing is that i damaged the original battery... so i can not test it..
i also tried several chargers. before the change everything worked well.
I hope its only the battery so I ordered another one and i will try in on monday ..
thank you for your help!
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 99
