Salta al contenuto principale
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456 Domande Visualizza tutte
Domanda Chiusa
My R button on my 3DS is stuck down. How do I Fix it?
The button is stuck in the "pressed" position. To get my 3DS to respond as if it weren't being press, I have to pull the edge of the button up. When it goes back down, I do not hear the clicking sound the other 3 shoulder buttons make when they're pressed. The button is stuck down on the right, away from the center of the system. I've uploaded some images as well.
http://imgur.com/a/byG8P
The 1st and 3rd images are of my L button, which isn't broken. They're there for quick reference.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
There is a small spring that pushes the button out this may be broke or the pin that holds the spring may have slipped if your game to take the controller apart the spring is similar to what you would find in a retractable pen
Nintendo 3DS Right Shoulder Button Replacement
The guide can help you through the teardown
Punteggio 2
1 Commento:
this spring will be a lot smaller just looked in a pen for reference and its definitely gonna be different
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 7,532
