Salta al contenuto principale
Released May, 2013. Display - 1200 x 1920 pixels, 10.1 inches. Chipset - Qualcomm Snapdragon APQ8064, CPU - Quad-core 1.5 GHz Krait, GPU - Adreno 320. Memory - 16/32 GB, 2 GB RAM. Android OS, v4.1.2 (Jelly Bean), upgradаble to v4.4.2 (KitKat).
black screen and red led blinking 3 times
the lcd was broken after a drop. tried replacing the lcd assembly but now the tablet won't turn on. even with the old screen i can't seem to get it booted. tried al the button combinations but it didn't work. tried unplugging the battery for 10 min. still nothing. when i press the power button the led flashes 3 times, that's it...
any idea's ???
Questa è una buona domanda?
Punteggio 0
6 Commenti
when you replaced the screen did you disconnect the power before working on the tablet or was the battery connected during the replacement?
da
yes, I disconnected the battery before working on it...
da
Just a question do You know there's a shift button for a reason Ibar
da
Cody, I'm here to help people with their electronics. My first language is dutch, second is french. So please excuse me for my english and if sometimes I forget to write I with a capital I...
greetings iBar
b.t.w. Do you know there are buttons for punctuation? ;-p
da
Yes I do I am sorry.
da
Mostra 1 altro commento
Aggiungi un commento
1 Risposta
Soluzione Prescelta
iBar, this can be caused by a bad/drained battery. Make sure that you charge your Sony with a known-good charger/cable.
Punteggio 2
2 Commenti:
all i needed was the original charger :-)
da
Aggiungi la tua risposta
ifixshop sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 20
Tutti i Tempi: 20,095
