Salta al contenuto principale
My iPod screen is turning white is this fixable?
the Ipod felt on the floor and when I plugged it in too my computer the screen turns white... everything is working only I can't see what is playing and i can't choose a number because the screen is always white. is this fixable by myself??
Questa è una buona domanda?
Punteggio -1
1 Commento
I noticed you never got an answer to this. Are you still having this problem?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
The iPod has a liquid crystal display. A very thin capsule with a chemical compound which builds up the picture under an electrical charge. Likely is this capsule ruptured as a result of the fall.
There will no longer be any picture or pattern. All you are seeing is the electroluminescent screen (backlight) which shines through the crystals in the display.
This must be replaced as a complete unit. Relatively easy on the 4th gen nano.
The contents of the display are regarded as toxic so take precautions if you see any of this inside. Mop up carefully with camera lens tissues.
After plugging in the replacement give it a quick try before pushing it all back into place.
Punteggio 1
if i don't have a replacement for it can't i be give any other sol'n to solve this problem
Punteggio 0
Aggiungi la tua risposta
sam sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,024
