Salta al contenuto principale
Why is my transmission failing to shift after 30 mins of running.
I have a 2004 honda accord ex. After the car runs for thirty mins, the car will not shift out of first gear, when it is an automatic transmission. I have replaced the solenoid switch and the computer and problem continues to persist.
Questa è una buona domanda?
Punteggio 2
3 Commenti:
Hello Prentice, How many miles are on your transmission?
da
I hace the same problem in My accord I have spent a lot of Money and the continiu....
da
Somebody can helo me .......
da
Aggiungi un commento
2 Risposte
Check out this web page to help you trouble shoot, there is a ton of good info. http://www.hondaproblems.com/trends/tran...
Punteggio 0
Generally this is a sign of low or over-used oil.
I would check the oil level and its color first.
If you can do this, the trans oil should be a red color. If it is not, get it change ASAP.
Punteggio 0
Aggiungi la tua risposta
Prentice Walker sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,100
