Salta al contenuto principale
The Zune is Microsoft's portable media player and entertainment platform, originally released in 2006.
Zune error message "contact support 5"
Zune 120gb displaying error message
contact support 5
I followed the instructions on resetting it, but still no luck.
Questa è una buona domanda?
Punteggio 9
3 Commenti
Hi I have a problem my zune MP3 player says 5 contact support and it won't go away and I can't turn my zune off please help
da
I can't get nothing on my zune it showing 5 contact support how to get it off of the zune
da
ERROR CODE 5——Yes, It can be a HD ribbon ZIF cable loose , BUT 99% of the time the Hard Drive has gone bad. No Fix other than replacement. I have many ZUNE 120Gb players & One at a time the hard drives went bad. No reasons—not dropped. I found the best repair is sending them to RAPID REPAIR. For $20.00 they will diagnose & give you an estimate. The smartest repair is having the Hard Drive (which is mechanical & will go out again) Replaced with a SSD digital drive. No moving parts, Solid state Memory, WITH a plus that they can replace the 120Gb drive with a 128Gb drive with extra memory. I’ve now have all 4 of mine done, Some with a new battery at Approx. $ 200. each or less. Just don’t throw that old ZUNE away ! Even broken, It’s worth big money on EBAY to guys & girls looking for parts that are NLA to fix their’s. Hope this advice works for all that live with ZUNE everyday like me. The best player ever on the market.
da
Aggiungi un commento
7 Risposte
Soluzione Prescelta
If resetting it doesn't work, you should reinstall the software:
http://support.microsoft.com/kb/926993
Software available at: http://www.zune.net/en-us/products/softw...
You may lose music or other data purchased/added since your last sync.
Punteggio 6
3 Commenti:
Is the software on the website or the cd that
Comes with it?
da
I added the link to the software above.
da
da
I fix these for a living, the number Five Error is usually the hard drive, sometimes the hard drive cable.
Punteggio 3
1 Commento:
I've got two 120 gb Zunes, and one 30 gb. Both the 120's display this error screen; I believe the error message on the 30 was similar, but I cannot get it to appear again. Can you send me contact info if you can possibly repair these units?
da
i have a contact support 5 and there is a chip getting really hot on the motherboard.(looking from the back its on the lower right side, behind the back button on the back side of the board) still say 5 is the hdd or hdd cable?
Punteggio 1
ERROR CODE 5——Yes, It can be a HD ribbon ZIF cable loose , BUT 99% of the time the Hard Drive has gone bad. No Fix other than replacement. I have many ZUNE 120Gb players & One at a time the hard drives went bad. No reasons—not dropped. I found the best repair is sending them to RAPID REPAIR. For $20.00 they will diagnose & give you an estimate. The smartest repair is having the Hard Drive (which is mechanical & will go out again) Replaced with a SSD digital drive. No moving parts, Solid state Memory, WITH a plus that they can replace the 120Gb drive with a 128Gb drive with extra memory. I’ve now have all 4 of mine done, Some with a new battery at Approx. $ 200. each or less. Just don’t throw that old ZUNE away ! Even broken, It’s worth big money on EBAY to guys & girls looking for parts that are NLA to fix their’s. Hope this advice works for all that live with ZUNE everyday like me. The best player ever on the market & A SHAME that MS ever ever stopped producing. But then again MS has never done too much right other than make the best music player on the market.
Punteggio 1
1 Commento:
Hi Robert. I recently sent a few email messages to Rapid Repair (8/2023) but have not heard back. They don't have a phone number listed on their website. Do you happen to know who else can fix the number 5 error?
da
I have visited you blog and feel good to read comments about to fixing the zune error 5 and other but now i am focused about to fixing zune error 5 someone recommend me to visit this error site and feel the difference of services and i follow that person and really i have get a lot of benefits from this its solve almost every problem related to this error, I want to recommend you to visit this http://ezinearticles.com/?Fix-Zune-Error... and you also feel the difference between this and others sites.
Thanks
Punteggio 0
After replacing my zune LCD screen I got this message. I took the zune apart again and found that I did not properly replace the mother board ribbon. After properly replacing the ribbon, the zune worked fine. Hope this works.
Punteggio 0
I tried nearly everything to no avail.. just for the heck of it, I band my zune on my desk a few times and *poof* it started up just fine... yup, I pulled a Fonzie.
Can't make the problem worse!
Punteggio 0
Aggiungi la tua risposta
Arthur sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 45
Tutti i Tempi: 43,673
