What kind of mild adhesive is used on bottom bezel?
When replacing the battery on 2nd gen ipod the bottom bezel won't stay attached. What kind of mild adhesive is recommended?
Questa è una buona domanda?
I'm a fan of a tiny bit of clear silicone myself for small fixes like that. It holds strong, is easy to work with, and can usually be cleaned up/off of things if you ever take it apart again.
If you want to duplicate the original adhesive as closely as possible, I would lay some double sided tape over the back of the bezel, then trim it around the holes/edges.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,209
