Salta al contenuto principale
Repair information for the first generation Apple iPad available in Wi-Fi and 3G versions with 16, 32, or 64 GB of storage. Released on April 3rd, 2010. Model numbers: A1219 and A1337.
266 Domande Visualizza tutte
Wifi Logic board in a 3G Ipad?
I have an original Apple Ipad 1 WIFI that im pretty sure has a bad Logic Board. When plugging it in the screen flashes for second and nothing else happens. Ive tried doing the resets, and everything else and I think its just a brick. Ive found WIFI only logic boards on Ebay for $35. My question is can I install a Wifi only Logic Board into an Ipad that has 3G with Wifi in it? Would there be a problem fitting it in? Are the logic boards different shapes and are there cables in the housing of the 3G that have to be plugged in to work? Thanks.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
You Can but you will also need to buy a wifi screen too because of the antennas thats attach on the frame of the 3g Screen you will also will have to get rid of the sim tray flex
I guess you can keep the same screen just tape the antennas so they dont move around.
Punteggio 0
1 Commento:
So I cant just use the same 3G Screen I have now?
da
Aggiungi la tua risposta
nickc75 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 135
