Salta al contenuto principale
there is gap between the top and the case
there is gap between the top and the case on the front can this be fix
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Your question is a little vague, but I'm assuming you mean a gap between the uppercase (with the trackpad built in) and the lowercase, not that the laptop does not close/latch completely.
This guide should walk you through removing the uppercase:
PowerBook G4 Aluminum 15" 1.5-1.67 GHz Upper Case Replacement
Inspect the parts for bends/damage, re-assemble correctly.
Punteggio 1
1 Commento:
+ good
da
Aggiungi la tua risposta
mike sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 770
