Salta al contenuto principale
Water Dispenser dispenses water slowly
I have a GE PFSS2MJXASS Refrigerator and the water dispenses slowly. Ice maker works fine. I recently replaced the water filter and valve and that did not fix the problem. When i unscrew the water filter and replace it the water dispenses fine for a short time and then the flow slows down. I hear air when the filter is connected to the refrigerator so i suspect the problem is with the part that you screw the water filter into. Any ideas on how best to fix would be appreciated.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You need to flush the air out of the water lines after installing new filter. Place a tall/large cup under the water dispenser and run the water untill the air is released. It usually takes 5 minuets or more and at least a gallon of water to remove all the air.
Punteggio 2
Aggiungi la tua risposta
markrubin25 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 53
