The top screen of my ds is floppy
the top screen of my ds is floppy it as no resistance when closing and just swings open an slams shut
Questa è una buona domanda?
It sounds like the hinge is broken or weakened. Also, if the screen is flickering or malfunctioning it is usually cause by a damaged flex cable when the hinge gets broken.
There are 2 parts you will need, the top screen, which can be aquired via ebay etc. and you'll also need a replacement housing. If the hinge needs replacing you will actually only need one housing part, the inside topscreen part. The ds requires a triwing screwdriver to open.
The step by step replacement guide on here will show you how to do it.
There's a website for stuff like this :o
http://www.Nintendorepairs.com/
I have the same problem and I just found it although I have not used it yet :T
You can get the tri wing screwdriver that Lori mentioned at nintendo screwdriver.com
Ultime 24 Ore: 5
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 107
Tutti i Tempi: 9,000
1 Commento
also the top screen flickers on to off and some times the images have a red hue or tint
da Micheal
