Salta al contenuto principale
Seconda generazione di iPhone. Modello A1241/8 o 16 GB di memoria/plastica posteriore bianca o nera. La riparazione è più semplice rispetto al primo iPhone. Richiede l'uso di cacciaviti e strumenti di leva e distacco con ventose.
1169 Domande Visualizza tutte
Are the headphone jacks interchangable between the 3G and 3GS?
Is the headset jack replacement part for the Iphone 3G the same as the one for the 3GS.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
See this answer: Can an iPhone 3G be upgraded with parts from an iPhone 3GS?
It's physically the same, but we haven't actually tested it. I'd guess it's worth a shot.
Punteggio 2
For the 3gs heaphone jack flex cable, it can work well on 3g. But the 3g heaphone jack flex cable can not interchangable with 3gs.
Punteggio -1
8 Commenti:
swone, have you tried it out?
da
er... i think you are wrong!
da
No, I am not agreen with you.I have emailed to the seller on ebay. They tell me sometimes they will just sell the 3gs headphone jack flex cable instead 3g and 3gs.
da
Yep I think you are wrong too. Unless of course you can say that you have done it yourself or anybody else for that matter.
da
No,I can sure that's correct. It is no meaning to clarify for it. If you do not trust me,you can have a try.
da
Mostra altri 3 commenti
Aggiungi la tua risposta
bryanjohnson2 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,204
