Salta al contenuto principale
Lo Huawei P8 Lite (Modello: ALE-L21), annunciato nell'aprile del 2015, punta sulla bellezza nella semplicità. Le sue fotocamere professionali permettono di scattare foto naturali e nitide anche in ambienti poco luminosi. La modalità beauty abbellisce il viso del proprietario in ogni selfie.
112 Domande Visualizza tutte
Where can I get a motherboard for my phone Huawei P8 lite?
Hello!
I accidentally dropped my phone into water, I tried to switch on the phone after trying to remove water by heating it with a dryer. The phone was working but I could see only huawei logo after that the screen was blank. But now when I try to switch on my phone, it is not working. I came to know from a person that if i replace the motherboard, maybe the phone would start working.
Please help me in this issue.
Questa è una buona domanda?
Punteggio 6
2 Commenti:
also dropped into water. all seems functioning well just my power button and volume button not working
da
Kya apke pas p8 lite ka mother board hai , power ic hai to phone kare +9779844276898
da
Aggiungi un commento
4 Risposte
Does any other function work? Such as sound, vibration. If yes, then it may be the screen broken. There seems no motherboard sold online, you may need to send it to the repair shop for help.
Punteggio 0
Volumes and power buttons are working but when phone is on it didn't show any logo and the touch works but the screen didn't display anything.
Punteggio 0
hello you solved ? I have the same problem , I replaced the display but nothing has changed .
If you solved kindly you explain to me how? thank you
Punteggio 0
Ebay:
https://www.ebay.com/itm/Placa-base-Moth...
Punteggio 0
Aggiungi la tua risposta
Syed Karim sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,585
