Salta al contenuto principale
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
542 Domande Visualizza tutte
When computer starts 4 beeps then nothing
I have a custom built computer with an Asus motherboard, and when I try to start it it beeps 4 times and then does nothing. The fans are running and the little green light is on the mother board but nothing else. Can anyone help?
ASUS M5A97 motherboard
AMD X6 FX-6300 cpu
G.SKILL Ripjaws 8GB ram
Corsair CS Modular CS650M power supply
ASUS GeForce GTX 750
Samsung 850 EVO 250GB ssd
Questa è una buona domanda?
Punteggio 0
3 Commenti
is it 4 solid beeps or are there spaces2 long 2 short
da
4 beeps all the same
da
Replace the cmos battery. That sometimes gives 4 beeps if dead or it is your ram. Try change positions and use one stick when testing
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Asus motherboards are usually American Megatrends' AMI BIOS. and if that's the case four beeps mean System Timer failure: Timer 1 on the mainboard does not work properly. This can mean that your motherboard has failed but before throwing it out there have been cases were the memory has failed on one dimm but not the other, so pull one dimm at a time and try to start it and see what happens
Hope this helps
Punteggio 5
4 Commenti:
I'll try this and let you know
da
one stick of ram didnt work the other did. its new just today so whats the deal. Thanks for the help looks
da
Found the A channel (a1 & a2) work fine, however, the B channel always issues the 4 beep System Timer Failure code on boot. Anyway to restore functionality? Or is this a permanent failed state?
da
johngonsalvesjr have you tried more than one dimm of ram or have you tried different dimm. it could be the stick or the slot so try different sticks . also remember that one slot is prioritized as first and unless it has a stick in it the second may not work . also just blowing the slot out may help as dust in the slot can cause problems
da
Had same problem with a z77 board. Had 2 different sticks of ram and would get the 4 beeps on every stick and slot I tried. Plugged in a different psu and it booted?!
Punteggio 0
i got same problem i tryed with new hardware all switched even new motherboard, ram,processer,psu,gpu, i tryed it all..problem still there when i boot up. and it does not beep every time some times there is 2 or 4 days between i get these 4 beeps
Punteggio 0
Aggiungi la tua risposta
Chris sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 27
Ultimi 7 Giorni: 150
Ultimi 30 Giorni: 595
Tutti i Tempi: 62,126
