Why is my battery not charging?
On the camera a red blinking sign of a low battery continues to show after having the battery charged over night.
Questa è una buona domanda?
If your battery is not being charged you might need to replace the battery.
As Santos said, you may want to consider replacing the battery. If a new battery does not solve the problem, it may be an issue with the charging cable or AC adaptor for the device or perhaps a loose cable inside the device.
before you go out and spend money on a new battery, just try to reset it. hopefully that will fix your problem.
How do u reset the battery on sony carl zeiss handycam dcr-dvd92e
good question, did u find out?
Id like to know too?
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 8
Tutti i Tempi: 2,840
