Salta al contenuto principale
The Motorola Moto G (2nd Generation), also known as the Moto G2, is the 2014 successor to the Moto G. The Moto G2 is equipped with a 5-inch 720p display and a Qualcomm Snapdragon 400 processor. Model numbers XT1045, XT1040, XT1039, XT1069, XT1068, and XT1064.
Battery life is short
Phone battery does not last as long as it should?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta Più Utile
First check to make sure that your phone is not running background apps that may drain your battery life. If this is not the cause try turning off mobile data and wifi and see if this affects the battery life. Again, if this is not the root cause of the problem, a factory reset of the device can be used to clear cached memory.
Punteggio 3
Aggiungi la tua risposta
Jacob Garzini sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 405
