Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
1624 Domande Visualizza tutte
Domanda Chiusa
No sleep and camera after spilling
Few weeks ago i spilled hot tea on my macbook pro, i taked out the whole macbook apart and washed in warm water & alcohol the keyboard and backlit...
after that assembled everything together, and the keyboard was bad i was pressing one button another one was responding, the trackpad had only a right click and the power button didn't worked to...
i buyed a new keyboard and a trackpad, assembled them and everything was ok till i closed my macbook...
the macbook didn't fall asleep after closing the lid, but it's sleeping when i press the power button or a manual sleep from the menu...
i received a facetime call today and when i answered it was no camera, and checked into photobooth it says no camera connected...i tried reconecting the camera cable but still the same...
i would appreciate the help for solving this, thanks :)
ps. i changed the hdd/ir sensor cable
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
It seems that the sensor detecting the lid closing and the motherboard connector for the facetime camera have been damaged. Have you seen any corrosion damage around these parts of the motherboard?
On a side note I would recommend that you use isopropyl alcohol and no water to clean the internal components of any computer as corrosion can travel within the soldering and might be damaged without any visible clue and using water could aggrevate the problem.
Punteggio 0
1 Commento:
I havent deteced any corrosion on the board, i tooked some pics if you could see
And what other sensor it could be for the sleep ?
da
here are some photos i took, i suspect the battery indicator causing no sleep...
Punteggio 0
any help or idea for further repair ?
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 98
